BX2350 drawbar size
/ BX2350 drawbar size
Just wondering what size drawbar should I purchase for my BX2350. Thanks.
/ BX2350 drawbar size #5
Why would you be using a Cat 0 drawbar when it's a Cat 1 hitch??
I have a Cat 0 drawbar for an older Honda tractor and the ends are far too small for use on my BX2200
I use a Cat 1- 26" but it does bind a little when fully raised.
/ BX2350 drawbar size #6
Thanks for your input. I called my dealer and told him I needed a drawbar... he said he had it in stock and would send it right out. Not sure of the specs, but I'll trust he knows which one will fit my tractor correctly.
I'm hoping to install the EZMover receiver hitch this weekend.
/ BX2350 drawbar size #9
Peter,
I bought the 20" primarily because I was concerned that the 26" would bind when raised. Plus it was a bit cheaper /forums/images/graemlins/wink.gif
I haven't had a problem attaching it to the lift arms on my bx, but I am sure that the 26" probably would be a better fit.
Thanks,
Charles P
/ BX2350 drawbar size #10
Peter,
Thanks,
Charles P
What do you guys mean by binding?
/ BX2350 drawbar size #13
The lift system is designed so that as you raise and lower the hitch, the horizontal distance between the two lift arms increases/decreases as you raise and lower it. Binding can occur if something like a drawbar prevents the contraction.
I don't know how much of an issue this really is because I haven't had an opportunity to use any 3pt equipment other than a drawbar and carry-all.
Hope this helps.
Charles P
/ BX2350 drawbar size #14
Hope this helps.
Charles P
Ah, I see. Thanks for the explanation.
/ BX2350 drawbar size #17
You want a 20" cat. 1 draw bar. I got mine at the local Farm and Barn store but have also seen them at TSC. Oddly enough, they're slightly more expensive then the 26" bars.
/ BX2350 drawbar size #18
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
17601CFL (A59228)
17601CFL (A59228)
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
Pat's QH and hydraulic top-link.
Pat's QH and...
