BX2350 Cheatsheet
   / BX2350 Cheatsheet #1
MoreCowbell
Clayton, NC
Kubota BX2350
After going back to my owner manuals for the 3,000th time to look up frequently used info on my BX2350 (e.g. tire pressure, oil type, etc.), I decided to put it all on one cheatsheet I can thumbtack to my garage wall. I don't know if anyone has put together something like this previously, but I figured I'd post it here for any other BX2350 owners.
Everything was taken word-for-word from the tractor/mower/loader manuals - even the weird stuff (e.g. mixing metric and standard in the loader specs).
Anyway, hopefully this will help someone keep their manuals a little less greasy.
  • BX2350 Cheatsheet.pdf
   / BX2350 Cheatsheet #2
I don't agree with the factory air pressure other then those are the max pressures for those tires. You shouuld always run with a full tire on the ground.
   / BX2350 Cheatsheet #3
I like the idea of a cheatsheet, its a PITA to look up the info all the time...wish I had one for my BX23 and 60" MMM..
   / BX2350 Cheatsheet #5
We're you going to post the cheat sheet? This is a great idea! I would like to see what you have put together and modify as needed for my BX25.
   / BX2350 Cheatsheet
DAT, I attached that file to the original post. It's a PDF file. Can you see it? I can private message it to you if you are having a hard time pulling it down.
   / BX2350 Cheatsheet #7
Is'nt this the same engine thats in the BX 25 and BX 2360 basically the same tractor?:confused::confused:
   / BX2350 Cheatsheet #8
That's great. Any chance you have the original word version to save me some editing time? Thanks!
   / BX2350 Cheatsheet #9
That's great. Any chance you have the original word version to save some editing time. Thanks!
   / BX2350 Cheatsheet
Hello. I should have posted the original Word doc initially. Here it is...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
43014 (A51691)
43014 (A51691)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
Chery 10' 18 Drawer Workbench (A50121)
Chery 10' 18...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
