Bx2350 acts like staving for fuel
   / Bx2350 acts like staving for fuel #1
davideoftex
I have tried almost every thing. Removed tank to check for blockage, did the seat mod of removing one of the metal pieces, bypassed the fuse so that I had to kill the engine under the hood, replaced both filters and today the fuel pump. I have searched the web and see the same complaints and never see any remedy.
The only thing left is the injection pump, help please
   / Bx2350 acts like staving for fuel #2
I'll ask a couple question, you've probably already done them but I'll ask. Have you taken the fuel line off in various places to see if you have good flow, such as after the rear filter, it should flow well by gravity. I'd also try it before the main injection pump with the key on to make sure it's getting fuel there.
There was someone on this board that had the main injection pump go bad, but it's not common.
I also assume you have checked your diesel to make sure it's clean and doesn't have algae or a lot of dirt.
Yes I have good flow to the fuel pump, I have taken the fuel cap off to make sure it is venting. The fuel pump (new and the one I replaced) have the same pressure by using my finger as a gauge. The fuel is used up often so it's never old.
My next thought is using the other fuel pump, a Y from the tank to both fuel pumps check valves to engine for more pressure. The second fuel filter doesn't stay full. If I can't figure it out, a new tractor 13,000$��, the grass keeps growing
   / Bx2350 acts like staving for fuel #5
My BX25 did the same, because of a parking brake that would not fully disengage. When I put a load on the engine it would stall. Once the dealer fixed it the problem never reoccured. Strange, but true.
I will check it out, thanks for your input
   / Bx2350 acts like staving for fuel #7
You will find a lot of posts about adding a Racor filter to the BX's. My rear filter would plug up, but maybe only once a year. I would cut that filter open and it never looked bad, but you could tell when you took the hoses off it was plugged up. I'm not saying thats your problem but the filters are so small the plug easy.
If you can see the second filter isn't filling up well, it almost has to be a plugged tank, filter, hoses etc.
   / Bx2350 acts like staving for fuel #8
My question would be "how old are the hoses?" could be when fuel draw is heavy when under load the hose is collapsing on the inside restricting fuel flow.
The hoses are in great shape, both filters are new.
It doesn't seem to have problems with full tank of fuel. When it gets low I will try and pressure the tank up and blow it all out although it flows free through hose
a racor as filter has been ordered
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
Ryobi Weedeater (A51573)
Ryobi Weedeater...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
