BX23 with 550 hours
   / BX23 with 550 hours #1
Rusty4242
Bronze Member
Western Mass.
Kubota BX23
I found a BX23, 2001, he says, with 550 hours on it.$10,500. Assuming it looks ok , how can I tell if the tranny is OK? Or do they last forever?Thanks, Rusty
   / BX23 with 550 hours #2
I'm not sure but I think the BX23 was made in 2003 and 2004? I bought mine in Dec. 2004 and the BX24 hit the market around the end of 2005. I'd get it real hot and try to stall it against something in 4 wheel drive. Look up under it and see if all the blades are on the hydro fan and boots were still intact.
   / BX23 with 550 hours #3
Rusty4242 said:
I found a BX23, 2001, he says, with 550 hours on it.$10,500...
This does not sound entirely correct. Where is the tractor being advertised?
   / BX23 with 550 hours #4
MScott is closer, maybe right on.
I bought my BX2200 in 2003, when the BX22 was selling. The BX23 came out soon afterward, and was out ?? years (not many), before the 24 came out.
The year 2001 is wrong. Can't speak to the other info.
ron
   / BX23 with 550 hours #5
From what I had read, the HST trannys are built to last for a long time. Much longer the 500 hours. The pushing idea does sound like a good test. I would also inspect around the housing for any signs of leaks. If the machine appears to be well kept, that tranny should go 1000s of hours more.
   / BX23 with 550 hours #6
I don't think even the BX22 was out in 2001. I bought my BX2200 in 2000 and all the big heated debate re. whether such a sized tractor could take a backhoe had not begun yet. In fact, I remember talking to a guy in 2002 who had bought a B series because it had a bh. He'd wanted a BX, but since no BX had a bh, he had to shell out for the B series. I think the BX22 came out in late 2002 or early 2003. The BX23 was even later.
If one piece of info. is wrong, the greater the chance that more of it is suspect as well.
   / BX23 with 550 hours #7
I bought my BX22 in May of 3003, and I believe it was just about a year old. I do remember thinking that mine was the first year of production..
Thanks, gents. He made an error with the date. It is a BX23. I'll look at it this weekend and let you know what I find. thanks, Rusty
2017 Terex Warrior 1800 Screener (A50322)
2017 Terex Warrior...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
