BX23 - What is this?
   / BX23 - What is this? #1
AMR
Woodbury, CT
B3030
I posted a few days ago that my BX23 is leaking hydraulic fluid around the rear somewhere. I mowed last night and had to run nearly WOT for about 3 hours to get the grass cut and bagged, it really looks good. I would guess that I lost about a teaspoon of hydraulic fluid in the process. Needless to say I was very upset seeing hydraulic fluid all over the back of the tractor.
I took the opportunity to look for a where the leak was eminating and it appears to be coming from directly under the seat. If you look under the seat you will see what looks like a red cap sitting on a washer. I always thought that this was an operator presence switch, but it is obviuosly not, silly me.
Does anyone know what this is? Might this be a vent of some type? Could my hydro fluid be a little overfull and pushing itself out of this?
   / BX23 - What is this? #2
It is the hydraulic cylinder breather. I would think that an overfull hydro unit might cause some seepage, but it's just a guess on my part. I just checked mine and found it appears to have vented a very small amount over the past three years so I would think that some kind of venting there is normal.
   / BX23 - What is this? #3
Seeing that you have a BX23 and the problem is new have you been digging in wooded area's? The sub-compacts all have little fans attached to the driveshafts to help cool the transmissions. These fans are plastic and often limbs can go up and break off the fins.
   / BX23 - What is this? #4
Losing a teaspoon of hydraulic fluid for every three hours of WOT operation is not a problem..... ;)
   / BX23 - What is this? #5
I had something like this happen as well. Only for me it seemed like A LOT of fluid leaked from the same area, I noticed this by seeing a trail of drops on the ground as I finished mowing. Of course I immediately parked the beast and looked for the issue, but only found the rear of the mower (Under the seat) covered in fluid along with lots of lawn clippings. I let it sit till the next day, pressure washed it, and ran it but found no leakage - I have run it several times since also with no re-occurance. I checked the levels which were found fine, and I had not changed fluids for some time prior to that. The cap you mention is in the area I saw fluid so I HOPE it was spurious and not a real issue. I had noticed that the entire assembly gets quite hot during operation and while the fan appeared entact the last time I checked it I will check again. Of course even just a quart of fluid looks like a lot when it's coming from your ~$14000 lawn mower just out of warrantee.
AMEN, anything leaking out of my $20,000 lawnmower bothers me. I had the dealer pick it up this morning, I hope to hear Monday and I will let you all know what they say. They were not as alarmed by all of this as I am, suprise.
I have found now how naked you feel without this machine. I use it to do so much so often that now that it is gone I feel anxious, like I have stuff to do but can't, that is the drawback with one machine that does it all, but then again, I can't afford more than one so I may as well have one that does do it all.
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2019 JLG 2682 26FT Scissor Lift (A50322)
2019 JLG 2682 26FT...
Wolverine Mini Skid Grapple Bucket (A50514)
Wolverine Mini...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
