bx23 trailer size
   / bx23 trailer size #1
tommu56
Elite Member
Lycoming county pa
kubota bx23
I got my bx23 this summer and have used it alot and was looking at dump trailers was wondering what length any one else was using 14' is getting a little long and i have to stay under 7,000 gtw fro my truck (trailer will probibly rated heavier though)
   / bx23 trailer size #2
I am using a 6 x 12 and it works fine. Bought at Lowes for $999 2 years ago. It has a GVW of 3000 lbs, perfect for the BX22 or 23.
   / bx23 trailer size #3
I also have a 12' trailer (dual axle, dual brakes, 5,000lb gross, 4,300lb net.) The BX "fits" but is tight; the FEL sits over the front lip and the BH has to be swung to one side to fully close the tailgate/ramp.
I would caution you on getting too "heavy" a trailer:
1. It will tempt you to overload your truck.
2. Too big a trailer will actually decrease the amount you can move. You need to keep in mind net load. Most steel 7k trailers weigh 1800-2200lbs which means you can tow an additional 4800-5200lbs. If you get a bigger trailer that additional tare weight eats into your capacity.
Good luck!
   / bx23 trailer size
i was looking at a 5' by 14 bed to keep wiggle room front to rear (balance)and keep it narrow to limit load wt and to keep track close to my truck width. I haven't found one made that size yet and won't need it till late spring. I have built all my other utility trailers to date but I don't have access to shop any more.
   / bx23 trailer size #5
I have a PJ 5 x 14 trailer (non-dump). It is well made and seems to work great for my BX2200.
I don't know if PJ makes dump trailer, but they are good from what I've seen.
They are out of TX, but I bought one in KS.
Ron
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2005 Freightliner Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Freightliner...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
