BX23 Torn Boot
   / BX23 Torn Boot #1
mscott
Bronze Member
WV
MF1533Cab&KubotaBX23
Has anyone had a stick rip off the rubber boot just before the hydro fan? I've read of a few fans getting broken by sticks but I guess I got semi lucky and the stick hit the fan and kicked it back and ripped off the rubber boot. Just wondering if I need to change it right away or I may be able to seal it better with silicone? Is there a bearing the boot protects?
Thanks for any help.
   / BX23 Torn Boot #2
I had the same thing happen, BUT did not tear the boot. BUT it did take out the wires to the fuel pump. Make sure u can hear the pump running before u turn the engine over.
   / BX23 Torn Boot
The tractor still runs ok it just made a bad vibration and I shut it down. After removing the stick it started and ran fine. Just found Bro-Tec i'm gonna armour it.
   / BX23 Torn Boot #4
Mscott,
I just tore the same boot this past weekend, and was wondering if you had yours repaired, or did it yourself, and what your experience was. Any info would be appreciated.
thanks,
2014 Honda Accord Sedan (A50324)
2014 Honda Accord...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2013 BMW 528i Sedan (A50324)
2013 BMW 528i...
20' Sea Container (A50774)
20' Sea Container...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
