BX23 Rear hydraulic connection
   / BX23 Rear hydraulic connection #1
BotaGuy
Wisconsin
Kubota BX23
Since it has been raining, I have been thinking about the rear hyd. line that connects to the backhoe. With the back hoe off, the line gets reconnected to itself. BUT, if the line were fed into a valve for a Log splitter? Top and Tilt system? the list may go on? Does this make sense? If I set up a control block, and plumbed the system with the back hoe line, would this work?
   / BX23 Rear hydraulic connection #2
Yes it will work.. You just have to get the proper valve set up that allows the fluid to flow through it if the valve is in a neutral position. I believe that they are referred to as open center. There has been a lot of discussion in the past. read here.
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2016 Autocar Xpeditor Garbage Truck (A51692)
2016 Autocar...
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
John Deere 3025E (A50120)
John Deere 3025E...
2012 Ford F-450 XLT (A50120)
2012 Ford F-450...
