BX23 - pinched hydraulic hose while attaching FEL
   / BX23 - pinched hydraulic hose while attaching FEL #1
Bill_BX23
North Georgia
Kubota BX23 (2005)
Oops. Saturday afternoon about 15:00 (after the dealer was closed and other local places were closed) I went to convert my BX23 from a mower to a digger. After removing the 60"MMM, I went to attach the FEL and, while being slightly distracted by my 5 year old asking questions, noticed that the right side of the FEL mount wasn't seating properly. Upon further investigation, I saw that I had pinched the middle hydraulic line going to the control valve (the one with the 90 degree end and the orange tape). Unfortunately, it bit into the line and I had hydraulic oil oozing all over the floor.
After a little tugging and jerking, I was able to manually remove the FEL (rope hoist helped) and found an auto parts store still open that made hoses. 18:00 and everything was back together and I was able to start working on a 24" pine stump.
I think I still may have a leak somewhere though - I will check the fittings to make sure they are tightened enough. Can't see any oil, but upon checking the level, it is always low.
Moral of the story: Be careful driving into the FEL and attaching it, so you don't pinch the hose. My hose cost $23. Dealer quoted me $25 today. Luckily I only had a few hours downtime and was able to get in 6 more hours digging on Sunday (still don't have the stump out of the ground.
Bill.
   / BX23 - pinched hydraulic hose while attaching FEL #2
I pinched the return hose once while re-installing the backhoe. I didn't cut mine though, luckily. The hoe just stopped working before it got too far to cut the hose. I had to lift the back of the tractor with a jack and let the hoe drop a little so I had hydraulic flow again. After than, just moved the hose and installed the hoe. Good thing it wasn't worse.
CFG Industrial H15R (A50121)
CFG Industrial...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
Wolverine Fork Extensions (A50515)
Wolverine Fork...
Deere 333G (A50120)
Deere 333G (A50120)
STORAGE FEES (A52141)
