BX23 MMM won't lift
   / BX23 MMM won't lift #1
m3rd
Somerset Cty, NJ
Kubota BX23
Hi all,
I was using my 54" MMM on my BX23 along with a Cyclone Rake to suck up leaves. Everything was fine and then at some point the lift on the MMM stop working. The 3PT hitch is working fine. I had to manually lift up the deck and set the hgt up so I could clear obstacles. Anyone have a clue as to what happened?
   / BX23 MMM won't lift #2
There's a rod that connects the 3point lift to the mower lift arms. Can't remember what side it's on, but it should be pretty obvious when looking at the back of the tractor inside the wheel wells. I'll bet there's a pin that fell out on you...happened to me this spring. Retraced my steps, found the pin, washer and spring clip...put em all back in real easy.
Thanks Charliebrn. I'll take a look for that.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
John Deere 9620R Tractor (A53342)
John Deere 9620R...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
