BX23 Engine sputtering
   / BX23 Engine sputtering #1
lawlopez
New Boson, NH
JD X450, Kubota BX23
I was using my BX23 all day, york raking, and all of sudden it stated sputtering.
touching the treadle (to go forward) made it sputter.
I figured it was fuel starved so I lowered the throttle very low and started climbing up the 1200' driveway.
After a while I got tired of this and went back to full throttle.
I was running at full throttle quite a bit at the time of the problem.
The tank showed half tank, this fuel came with the tractor when I got it on July 31.
   / BX23 Engine sputtering #2
Check the first filter from the fuel tank ( under the operator foot platform )
and then , if it's good , check the tank for leaves etc .
   / BX23 Engine sputtering #3
I had a similar problem with a used BX I bought in June. One of the dealers selling points was that it came with a full tank of fuel. After some research I found that this tractor had sat on the lot since last fall. Pulled both filters, drained all the fuel, replaced the filters and all has been good since. Pretty cheap and easy fix actually.
Mine did not sputter however, mine just lost power and stopped climbing hills.
Hope this helps.
   / BX23 Engine sputtering #4
did you visually check the tank instead of relying on the gauge? I would replace the fuel filters too, since it was used and you had it less then a month. Check the seat switches too and make sure its firmly clipped in.
I checked the fuel level and it was pretty low.
Filling it up didn't seem to do much to the fuel gauge.
So I'm going to keep my eye on that.
The fuel gage isn't indicating right.
It got so bad that I had to tow it today.
I opened up the line from the first filter to the pump, fuel came out at a reasonable clip.
So, I guess, the next thing to do is open up the line after the fuel pump to see if that is working right.
I'm certain I put some old fuel in it.
Curious thing, upon sitting it tends to work ok.
It's very sensitive to hills.
Uphill is a problem.
Larry
   / BX23 Engine sputtering #7
It's fuel starved,,,when your in a "no load" situation, the engine will run easily,,it's when you "load" a diesel that the fuel volume is called for, you either have a restriction or a leak and your sucking air
   / BX23 Engine sputtering #8
I had a very similar problem with a used BX2200 I bought. Once it warmed up it would gradually lose power until it wouldn't even climb my driveway. It had a full tank of fuel when I bought it which was at least 6 months old. I replaced both fuel filter and drains the tank in the process. It has been fine ever since. At about $8 each I would start with this. The odd thing with diesels is that the engine sounded fine but with load it would just bog down and die.
   / BX23 Engine sputtering #9
Try a the new style fuel cap. I had similar problems. Original fuel cap on bx23 allows rain water into the tank. A new fuel cap will eliminate the problem going forward. Obviously you will have to change the fuel and fuel filters to remove any residual water.
Wow, I would have never thought of the fuel cap, thanks.
I'll start with drain the tank and change the filters.
How do I clean out the tank ?
Run some gasoline through it ?
Larry
2017 Jaguar F-Pace SUV (A50324)
2017 Jaguar F-Pace...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
Homemade Creep Feeder (A50515)
Homemade Creep...
2006 Dodge Sprinter 2500 Van (A50323)
2006 Dodge...
