BX23 ENGINE IN BX24 ?
   / BX23 ENGINE IN BX24 ? #1
Joe_BX24_MA
North Shore, Massachusetts
KUBOTA BX24
Any BX24 owners out there ever wonder why the engine says "BX23" on it? Just something I have been wondering about and never asked. I have had my BX24 for almost a year now. Great tractor!
   / BX23 ENGINE IN BX24 ? #2
I'm gonna guess because it is from the 23? I don't know what changed between the two other then the highlights I saw when we were shopping for the 24. Mine says 23 on it as well.
   / BX23 ENGINE IN BX24 ? #4
Only 1HP per the Kubota website. That can be done as easy as tweaking the fuel system.
   / BX23 ENGINE IN BX24 ? #5
My 2004 BX23 has the D905 engine in it and it's rated at 22hp. Kubota also put the D902 engine in the BX23/BX2230's at some point.
What model engine does the BX24/BX2350 have?
If it's the D902 then some later model BX23/2230's may actually have 23hp.
Likes been said, alittle tweaking of the fuel delivery system can gain 1 hp.
   / BX23 ENGINE IN BX24 ? #6
HI ,
Wasnt there something on here a while back ,about Kubota mis converting some numbers which made the 23 actually 24 hp? Does any one recall that ?
ALAN
   / BX23 ENGINE IN BX24 ? #7
My BX2350 engine has a sticker that says BX23
   / BX23 ENGINE IN BX24 ? #8
Joe_BX24_MA said:
Any BX24 owners out there ever wonder why the engine says "BX23" on it? ...
I have the Operator's Manuals (showing the specifications) for both the BX23 and BX24 in front of me. The engine displacement for both units is the same at 54.8 cu.in. However, there are small differences between them
The BX23 Engine Type is D905-E2-BX, the Engine Gross HP is 22, and the Maximum torque is 40.5 (at 3200 RPM).
The BX24 Engine Type is D902-E2-BX-2, the Engine Gross HP is 23, and the Maximum Torque is 41.4 ( at 3200 RPM).
Further, if you look at the mower attachment for the BX24, it actually says BX23 on it, yet it will not readily fit a BX23.
   / BX23 ENGINE IN BX24 ? #9
Kubota has labeled some of theBX series engines wrong at times.
My BX2200 engine was labeled as a one liter (1000cc) engine. Check the casting number on the block itself. I believe it will say D905 if it was an older BX2200 and D902 on the newer ones except for the 18 Hp. BX tractor.
   / BX23 ENGINE IN BX24 ? #10
Here's a list for engine replacement. IMHO, the difference would only be some tweaks, the part numbers are not the same as said previously. BX2350 and BX24 are the same.
  • BX series replacement engines.pdf
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A51222)
2020 VOLVO...
2018 JOHN DEERE 310SL HL BACKHOE (A51242)
2018 JOHN DEERE...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2015 GMC Arcadia SUV (A50324)
2015 GMC Arcadia...
