BX23 3pt hitch upgrade
   / BX23 3pt hitch upgrade #1
JRBX23
Rochester NH
KIOTI CK20HST
I read an article on this site about an 3pt hitch attachment that would increase the lift height of the 3pt hitch attachments on the BX23. Has anyone tried one of these attachments and where did you purchase it from. Thank from
New Hampshire.
   / BX23 3pt hitch upgrade #2
I don't know about an attachment ( I do remember reading something about someone developing one...) but...
Here is a link to a thread that outlines a simple modification you can make to get more lift.
I've done this myself on my BX2200 and it made a world of difference. I drilled the new hole about 1.25 inches higher in the lift rod end, if I remember correctly. I did not drill any new holes in the lower arms...
Take a look at that thread, it might be helpful... /forums/images/graemlins/smile.gif
   / BX23 3pt hitch upgrade #4
you know the adjustable arm on the right side to level your attachment. They are only $25. I bought one and put it on the left side and I got a lot by adjusting them both up
   / BX23 3pt hitch upgrade #5
Chucko,
That is a great idea! I've been wrapped up in adding two tilt cylinders to my b2910, so I would not have to sacrifice any lift ability with installation of T&T, but it never occured to me to do what you have suggested on the BX!!!
Great idea, since the BX 3PH goes down lower than it probably ever would have to, but needs more height when up.
And you get more tilt capability to boot, if you ever need it, since "full stroke" of that threaded lift rod would be available in each direction.
I'm going to follow in your footsteps on this one... /forums/images/graemlins/cool.gif
   / BX23 3pt hitch upgrade #6
I just added the "Pat's" system to my BX this past weekend. Awesome and worthwhile system and it adds 3 inches to the length of the 3pt and a resulting higher lift.
2000 Gallon Fuel Tank W/Pump (A50774)
2000 Gallon Fuel...
2013 JLG G9-43A Telehandler (RUNS) (SMOKES) (A50774)
2013 JLG G9-43A...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
2016 Dodge Caravan Van (A50324)
2016 Dodge Caravan...
Set of Tractor Tracks (A50514)
Set of Tractor...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
