gerford
Bronze Member
My 3 point hitch lever has started to stay in the "up" position when I raise the mower deck. Usually when the deck reaches the top of it's range the lever would automatically return to center. It now stays in the raise position and you can hear the hydraulics straining. I took it to the dealer and the mechanic says its about a 6 hour job to get at something inside that rusted and its not worth fixing because it will happen again. He also said it happens when you keep the backhoe on the BX a lot.
It doesn't sound quite right.
A couple of questions are:
Any idea what would keep the lever from going back to neutral?
If this happens to BX's and even fixing it doesn't help since it comes back, there must be a bunch of BX's with the same problem. Anybody else have the same problem?
Does it hurt to keep the handle in the "up" position since you can hear the hydraulics strain. My nephews sometimes mow the grass and hate to have them damage the machine by accident.
