BX2230 vs. the new BX2350?
   / BX2230 vs. the new BX2350? #1
RickO
Central, Ohio
Kubota G1900
I can get a left-over 2230 for about $700 cheaper. Is there any great advantage to the newer BX2350?
I think the BX2350 looks cheaper.
   / BX2230 vs. the new BX2350? #3
In my opinion their is no great advantage to the bx2350. Just a bunch of small improvemnts that make a general nicer machine. No major leap just small advances such as slightly increased power and lifting capacity, curved loader etc.
   / BX2230 vs. the new BX2350? #4
   / BX2230 vs. the new BX2350? #5
Rick,
OK here goes. I went from a BX2230, which is a fantastic machine to a BX24, which in every way, is a far better tractor.
I'll start from the front and probably forget several items:
-Loader - Next generation design. Better lift capacities. Better visibility. protected hoses. Better removal/install.
-Headlights - now halogen. much brighter.
- Front axle dipstick/cap. now an o-ring plug. no more pressurized front axle. seems to vent where the old style would build up pressure.
- Motor - more HP. new airbox mount. alternator instead of mini generator.
- loader valve - frame mounted. linkage actuauted. much neater and ergo friendly.
- seating/ deck area - much larger and comfortable. treadle under deck. better seatbelt design.
- dash - larger guages. now has digital tach. better cruise control.
- 3 point hitch - 1/4 inching valve. much higher lift height for implements. improved fill/dipstick design for hydro.
- 12 volt acc. outlet.
- backhoe - better curved design. protected hoses. better mounting method. more legroom.
dislikes--------plastic............
Worth $700? to me yes! but you won't go wrong with the BX2230. I just decided I wanted a Backhoe and my dealer gave me a great deal on his first BX24 back in the winter.
   / BX2230 vs. the new BX2350? #6
Rick,
   / BX2230 vs. the new BX2350? #7
<font color="blue">
OK here goes. I went from a BX2230, which is a fantastic machine to a BX24, which in every way, is a far better tractor. </font>
Ha, ha, ha... /forums/images/graemlins/blush.gif
I think the backhoe on the BX24 is REALLY what made that transition so much better...!!! /forums/images/graemlins/grin.gif
But I agree...I would spend the extra $700 and get the newer machine, if for no other reason because I would know I would get it back on the other end, if I ever needed to sell the machine.
Glad to hear you love that BX24 Renob...I would too if I had one in place of my BX2200...except that I have my B2910 TLB, which I don't doubt that I love even more than I would a BX24! /forums/images/graemlins/grin.gif
   / BX2230 vs. the new BX2350? #8
<font color="blue">
   / BX2230 vs. the new BX2350? #9
I am guessing you can do better than $700 cheaper on the 2230. I compared the same two machines back in March. My dealer had two 2230s left, and had just started to get in a few 2350s. He gave me $1,500 off on the 2230. Part of that was a $500 rebate directly from Kubota, if you went with their interest free financing, so the dealer actually gave me the 2230 for $1,000 less (plus Kubota's $500 rebate).
If the offer had only been a $ 700 difference, I think I would have gotten the 2350, if for no other reason than it is a newer model and will have higher resale value. I also went with the 2230 because the 2350s had just started coming off the line, and I wanted a model that had had the bugs worked out. That shouldn't be a problem now with the newer model.
   / BX2230 vs. the new BX2350? #10
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2012 Mack CXU613 Sleeper Truck, VIN # 1M1AW07Y3CM018973 (A51572)
2012 Mack CXU613...
2023 UNVERFERTH 632 LOT NUMBER 178 (A53084)
2023 UNVERFERTH...
