BX2230 runs great until.......
/ BX2230 runs great until....... #1
WinstonIII
Central Mississippi
JD 4440,Kubota 2230,JD 2550
tractor idles and wide open just fine until i move trans lever in low or high range or when i engage pto tries to go dead .....
/ BX2230 runs great until....... #2
One of the safety switches is out of adjustment. Check the seat switch first
/ BX2230 runs great until....... #4
WinstonIII said:
.........out of curiosity just how many safety switches on the Bx2230?
Safety switch under the seat, on the transmission selector, and the PTO selector. Not having a BX2230, I have pointed out the most common safety switches. Yours might have additional switches that I am not aware of, but the principle remains the same. I haven't gotten into any of these units, but my guess is that it is some form of micro switch and is easily defeated for testing purposes with a jumper wire. Once you figure out which switch is giving you the problem, then analyze how it works and see if you can adjust it to work properly. Test after making any adjustments to make sure that your adjustment hasn't disabled the switch entirely. By using the jumper wire, you don't disturb the adjustment and try adjusting the wrong switch. Dusty
Case 2090 Tractor (A66285)
Case 2090 Tractor...
UNUSED ATSPOWER PLASMA CUTTER (A64281)
UNUSED ATSPOWER...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
Sakai SW354 (A64126)
2013 International DuraStar 4300 Ledwell 2,000 Gallon Water Truck (A61573)
2013 International...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
