Snow BX2230 plowing snow. Turfs vs. Ags
   / BX2230 plowing snow. Turfs vs. Ags #11
I have a BX2200 with filled turfs on it and plow with my FEL and a Box Blade on the back. I am on a cement driveway and have not had any issues with traction. If I do start to spin in two wheel then I just engage the front axle and no problem.
   / BX2230 plowing snow. Turfs vs. Ags #12
</font><font color="blue" class="small">( I've read about this before but it really isn't answered well. I have turfs on my BX2230. In the winter, will I need to purchase ags to plow snow (with a blade)? Do ags do much better in snow than turfs? Should I get the new ags loaded if I am going that way? Does the BX2230 do a decent job in snow removal. I need some opinions from those of you who use your tractor to plow in winter. Also, are the extra work lights necessary for this job?
Thanks A lot! )</font>
I think the first issue you will encounter is a steering one rather than a spinning issue.
   / BX2230 plowing snow. Turfs vs. Ags #13
Get a set of chains for the rears and you will have as much capability as the tractor provides (weight-wise).
If you want to run bar tires- run them on the front- around $100 for a mounted pair. Front and rear tires are the same size in both bar and turf and have the same rolling circumference, so they can be mixed.
This is what I do, although I use a blower.
I think I will keep using the turfs I already have for plowing. With the ballast box on the back, I think I will do fine in 4wd. I thought about chains but I don't want to mess up the pavement. If needed, I will buy some ags.
   / BX2230 plowing snow. Turfs vs. Ags #15
I have a BX1500 with turfs and 54" blade. The turfs were OK, but during the NE 2005 Blizzard, I had to plowed in increments. I did experience some slippage then. With that, I changed from turfs (w/ 50# bolt-on tire weights) to AGs (loaded w/ fluid). My traction increased greatly. No slippage at all. Excellent steering capability too, especially when I needed to use the FWD. A new set of AG's (w/ rims) and shipping from tractorsmart.com cost me $375. I put the turfs back on for the summer for mowing.
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
UNUSED FUTURE BS72 72" HYD BOX BROOM SWEEPER (A58376)
UNUSED FUTURE BS72...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
Ammco Brake Machine (A55758)
Ammco Brake...
2022 John Deere Z930M (A57149)
2022 John Deere...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
