In order to try and solve the engine miss problem both fuel filters needed to be replaced. The filter near the fuel pump was only accessible if I removed the mower deck, which I did. While it was off I cleaned/greased all the deck components. Trying to re-install I could not get the splined shaft to reconnect to the mid PTO. I disassembled, cleaned, and greased the rear connector (the one with the three ball bearings that seat in the slot in the HST shaft) but cannot get the connector to fully seat and "click" into place. I also cleaned and greased the splined shaft from the HST to which the connector attaches.
Has anybody had this problem and found a solution? I really don't want to damage the HST shaft or operate the mower unless the connector is fully seated.
Did I mention access is terrible to this location under the tractor.
