BX2230 electrical issue
/ BX2230 electrical issue #1
ysgi
For some reason, my right turn signal (blinker for short) continues to blink.
The switch is off.
I cannot even get the left one to blink if I tried.
Also, the hazards only work with the key off. If I try it with the tractor running, they do nothing, just that right blinker keeps on blinking.
I removed and cleaned the contacts in the turn signal switch, but it still does the same thing.
Is there a relay or something that I should check?
-Eric
nevermind.
I guess I need to pay closer attention to my switch cleaning.
I took it apart again and cleaned it properly this time and it worked perfectly.
Thats what I get for being in a rush.
That blinking has been bothering me all summer.
-Eric
/ BX2230 electrical issue #3
Take her apart again anf use a grease gun needle and fill em' with grease. grease potted switches resist moisture related problems ... many marine grade switches are grease potted.
soundguy
2018 MACK LR GARBAGE TRUCK (A66091)
2018 MACK LR...
x (A68191)
x (A68191)
Jack Daniels Metal Decorative Sign (A66738)
Jack Daniels Metal...
2017 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A69167)
2017 FREIGHTLINER...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 FREIGHTLINER M2 4X2 S/A CNG FLATBED WITH CRANE TRUCK (A66091)
2014 FREIGHTLINER...
