BX2230 bullet connectors
   / BX2230 bullet connectors #1
lpp
Lenoir City TN
BX2230
I want to add some lights to my BX2230 to the connection provided under the seat. Are those standard bullet connectors or Japaneese bullect connectors?
I believe its 16AWG wire - would standard bullet connectors connect to what's on the tractor?
LPP
   / BX2230 bullet connectors #2
Mine were standard bullet connectors...My lights were the pits as well
   / BX2230 bullet connectors #3
If you are thinking of adding rear work lights, consider using the rear light circuit to power a relay which is fed from a separate fuse, instead of adding 50watt work lights to the tail light circuit....
So your suggesting no using the existing connecvtor - correct
How do I use a "relay" on the tail circuit?
   / BX2230 bullet connectors #5
See let there be light post right below this post
   / BX2230 bullet connectors #6
I believe he said to use it to power the relay.. so yes.. you would be using it. basically to turn on a switch.. and then you would need a seperate power run for the lamps themselves.. etc.
Soundguy
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58216)
2008 TEXAS BRAGG...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
WATER TRAILER (A58214)
JRB 90" GRAPPLE BUCKET (A58374)
JRB 90" GRAPPLE...
HAND SAWS (A58374)
HAND SAWS (A58374)
