BX2230 bullet connectors
   / BX2230 bullet connectors #1
lpp
Lenoir City TN
BX2230
I want to add some lights to my BX2230 to the connection provided under the seat. Are those standard bullet connectors or Japaneese bullect connectors?
I believe its 16AWG wire - would standard bullet connectors connect to what's on the tractor?
LPP
   / BX2230 bullet connectors #2
Mine were standard bullet connectors...My lights were the pits as well
   / BX2230 bullet connectors #3
If you are thinking of adding rear work lights, consider using the rear light circuit to power a relay which is fed from a separate fuse, instead of adding 50watt work lights to the tail light circuit....
So your suggesting no using the existing connecvtor - correct
How do I use a "relay" on the tail circuit?
   / BX2230 bullet connectors #5
See let there be light post right below this post
   / BX2230 bullet connectors #6
I believe he said to use it to power the relay.. so yes.. you would be using it. basically to turn on a switch.. and then you would need a seperate power run for the lamps themselves.. etc.
Soundguy
2016 Ford Transit 250 Cargo Van (A50323)
2016 Ford Transit...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50323)
1985 Eager Beaver...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
1998 SHERMAN +REILLY 6048 SINGLE DRUM LINE PULLER (A50322)
1998 SHERMAN...
2004 Ford F-350 Reading Service Truck (A50323)
2004 Ford F-350...
