BX2230 attachments - A & B Eagle
/ BX2230 attachments - A & B Eagle #1
lpp
Lenoir City TN
BX2230
I'm looking for a rear blade and box blade for my BX2300 a local dealer recommended A&B Eagle Sweetwater TN , which happens to be close by.
Anyone used their implements? Or recommendations of other brands...
/ BX2230 attachments - A & B Eagle #2
never heard of them. Do some searching. There are lots of posts on rear/box blades. I have a 48" gearmore box blade that I'm pretty happy with. Others like landpride or midwest. I think the howse and king kutter brands are lighter but many are happy with them. I wouldn't go bigger than 4' on a bx. My box blade can stop my bx23 in hard ground.
/ BX2230 attachments - A & B Eagle #3
I have the KK XB box blade (48"). It is build bery well. Without rippers, it weighs around 260lbs, or 300lbs with rippers in. I also have 2 5 gallon buckets fillled with rocks that I can place on if/when I need extra weight (they run about 80lbs a piece). The shorter sidewalls of the XB works better with the older model BXs due to there lower linkage hieght. I think the draft pins measure approx 12" off the ground where as other, full size, BBs are around 16-18".
You may be able to fit it, however your are going to definitely sacrifice max lift height. This is especially true when the rippers are down. I am with barry, the 48" can/will stop the tractor cold depending on the soil conditions. I loose traction many times before that happens.
/ BX2230 attachments - A & B Eagle #4
I have an A&B Eagleline Boxblade and rear blade, very well designed and built strong.I did a lot of research to build a landscape rake,and modeled the main frame after the A&B.
(6) 4ftx12ft platform grating  (A62679)
(6) 4ftx12ft...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
2014 Ford Explorer (A62613)
2014 Ford Explorer...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
