Pat's Easy Change BX2230 and the Pat's Easy Change System
   / BX2230 and the Pat's Easy Change System
Re: BX2230 and the Pat\'s Easy Change System
Danny,
Do you have the part number for those adjustable stabilizer links?
Update...
Folks,
FYI. The Pat's easy change system will not work with the Kubota GCK 60 Bagger kit. When standing behind the tractor, the right arm/system will not connect to the pin because the square box that contains the gear and shaft prevents the pin from entering into Pat's system. Pat's assembly is too beefy and just won't fit in the space available between the pin and the gear box assembly. If I can get a picture I will post later. This is in addition to the Top Link that I was going to have to modify for length. This mod would have been fairly simple with some steel stock and a welder but because of the other problem, It wont be necessary.
I am going to keep Pat's system though because I can put it on in 10 minutes and obviously it will help with the changing of my other implements.
Steve
   / BX2230 and the Pat's Easy Change System #43
Thanks for clarifying that. I didn't even consider that problem. Too bad because anything that would make it easier to put the bagger on/off would be appreciated.
KOMATSU PC170LC EXCAVATOR (A52707)
KOMATSU PC170LC...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
1111-A (A54756)
1111-A (A54756)
2016 Kubota SVL 75-2 (A53317)
2016 Kubota SVL...
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
