BX2230 air cleaner question
/ BX2230 air cleaner question #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
While moving some mud around with my FEL, today, I reduced engine speed to idle and noticed a rather loud rattling. I shut of the ignition after opening the hood and noticed the air cleaner seems to sit on a bracket with two holes perfectly aligned with two bolt holes tapped into its lower side, but no bolts. Can someone look for me and verify there are two small bolts securing the underside of the air cleaner to a narrow bracket?
Thanks all!
/ BX2230 air cleaner question #2
Yes, I believe yours should have two bolts holding the metal band that goes around the air cleaner. Some BX2200 have problems (mine) with the strap breaking at the bend area, not sure if they redesign that on the 2230.
Dave
I guess someone forget to install the bolts on mine. That's a point against quality control.
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
iDrive TDS-2010H...
