ewoz
Bronze Member
When I raise the 3 point hitch from the lowest position to the top it will stop raising when it gets about 3/4 of the way up. The engine then bogs down and the hydraulic hoses at the joy stick stiffen. If I then release the 3 point control and then try to raise the 3 point again it will raise a little bit higher and the same thing happens again. If I repeat two or three times eventually the 3 point will make it to the top. I bought the tractor new and it always did this. I am beginning to realize this is not right and it is an issue for the dealer, but if it is something I can fix I would rather do it myself.
Adjusting the nuts on the rod with the spring that attaches to the 3 point control does not fix the problem.
Thanks.
Thanks.
