BX2200 Weekends
   / BX2200 Weekends #1
Hootie
SW ARK
Kubota BX2200, Kubota ZD 221, Kubota Grand L 5030 HSTC, Kubota RTV, Polaris 500ATP
I have had this little bad boy for almost a month and already have 36 hours on it! We mow 5 acres and are building a new house. The things you can find to do with the FEL are endless.....The Woods box blade is proving to be very handy as a counterbalance and is moving lots of dirt for the flower beds and just general land leveling. I do not know how anyone that owns any amount of property could do without one of these things.
Of course we have to keep in mind that it is a tractor and that the grease gun needs to be handy (mainly the MMM) and that proper maintenance is a must for the extended life of the machine. My point is that there is work involved in owning one of these. But it is fun maintenance/work.
Count me tickled in SW Arkansas.
   / BX2200 Weekends #2
I'm jealous - I have had my BX200 since April and I have had several days of helping out the neighbors. But I have not had a chance to go tearing up my yard yet!! I may have to take a day off of work just for tooling around my yard - I WANT TRACTOR WORK!!
It has been fun at the neighbors, but after all, don't we all want to see how we can improve our places?
   / BX2200 Weekends #3
I have only had the box blade on once... Was working along the creek bank in wet sand..... Seemed to dig in too much. Need to do it again when it's dry. I wish the BX2200 had one thing though. A stop on the drop down to get the same height evey time. Even the old ferguson had that for the 3 pt. Maybe my box blade is too heavy for my 2200. Still learning to work with this fine machine...... Tom
   / BX2200 Weekends #4
did you adjust the down speed knob to see if it helped?
   / BX2200 Weekends #5
What model of box blade did you purchase?
KCook
   / BX2200 Weekends #6
It's called "Competitor" and made by Modern out of Texas. It's gray and 4' wide.......
Yes, I played with the speed knob and adjusted the Top Link.
I still wish there was a stop on the down lever. Maybe I will try somthing as simple as a bolt/washer and wing nut in the groove below the lever
I will try it again one of these days.......
   / BX2200 Weekends #7
Actually, there is a "stop" on the drop down. Under the seat you'll find a gold colored rod with a spring and a small bolt to hold the spring in place. Adjust where on the rod the bolt stops the spring and you've adjusted the drop down stop. I use this all the time to set the stop for my rotary mower.
   / BX2200 Weekends #8
Well, I will just have to look for that. Thanks Bill
Caterpillar 906M (A53317)
Caterpillar 906M...
2017 Ford Expedition (A56859)
2017 Ford...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
1R COLE PLANTER (A52708)
1R COLE PLANTER...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
