Backhoe BX2200 w/ a Backhoe! Why not??...
   / BX2200 w/ a Backhoe! Why not??... #11
Yes it is a subframe "type" mount, it's a four point mount. See attached pics.
   / BX2200 w/ a Backhoe! Why not??... #12
more
   / BX2200 w/ a Backhoe! Why not??... #13
another
   / BX2200 w/ a Backhoe! Why not??... #14
Last one
   / BX2200 w/ a Backhoe! Why not??... #15
jrlichina,
One of those photos was of the tractor without the bh attached. but it was a closeup of one attachment point. The next time you have the bh off, I'd sure appreciate a photo from a little further back so I can see how much hardware stays bolted onto the tractor while the bh is off. Does the subframe lower your ground clearance or get in the way of other 3ph implements while trying to attach them?
Did this bh come with your tractor new or did you buy it later? How much was just the bh?
Thanks for your feedback. I appreciate it.
   / BX2200 w/ a Backhoe! Why not??... #16
These are pics Wallenstien sent me when they were developing the mounting system for the JD, I don't have one. The upper mounts take hitch pins and the lower part of the backhoe mounts to a replacement bar that holds on the lower lift arms. Their system does not add any additional bracing or hardware other than the upper mounts so ground clearance is not diminished.
   / BX2200 w/ a Backhoe! Why not??... #17
I sent an e-mail to Wallenstein for more BX 2200-related info. Will post when I receive it.
regards,
Mahlon
   / BX2200 w/ a Backhoe! Why not??... #18
</font><font color="blue" class="small">( I sent an e-mail to Wallenstein for more BX 2200-related info. Will post when I receive it. )</font>
Thanks Mahlon. Can't wait /forums/images/graemlins/laugh.gif
   / BX2200 w/ a Backhoe! Why not??... #19
While researching this thread I noticed that the Wallenstein GX600 is circa 300 lbs lighter than the Woods 6500, so that makes it a far better backhoe candidate for the BX2200.
Wallenstein GX600: 625 lbs
Woods 6500: 950 lbs
None of this includes any subframe weight, though. And I doubt that it includes any weight attributable to the PTO-driven hydraulics (which is the only way I would use this on a BX).
Haven't heard from Wallenstein yet.
regards,
Mahlon
   / BX2200 w/ a Backhoe! Why not??... #20
I think this is the Landpride unit I saw at my local dealer. It appeared to be a 3-point that also had mounting to the frame if I recall correctly, but I did only look for a minute or two.......didn't want to start "needing one" /forums/images/graemlins/grin.gif
Landpride Bachhoe
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
