BX2200 Valve clearance check
   / BX2200 Valve clearance check #1
Barneyhunts
Dimock, Pa.
Kubota L4240 Kubota B7800, Kubota BX2200
My BX2200 has nearly 800 hrs. on it. Maintenance requirement is for a valve clearance check and I wonder if it is worth doing. Has anyone done it? What did you find? I use my tractor for mowing and snow blowing and have not noticed any drop in performance so I wonder if this check is necessary.
Thanks,
Barney
   / BX2200 Valve clearance check #2
Hi Barney. I did my first valve adjustment at 1170hrs. I only needed a minor adjustment to bring them into the mid-range of the specs.
Not a difficult task. Worth taking the time to check. Engine did run smoother afterwards.
Thank you for your quick response.
Barney
Have you ever seen a video on how to do this?
   / BX2200 Valve clearance check #5
I think there is one on youtube. If you have the workshop manual it walks through the process.
Thanks, I do have the manual. I'm not sure how to turn the engine over or how to determine TDC.
Barney
   / BX2200 Valve clearance check #7
Did my BX24 about 2 years ago. NOT hard. Used WSM. Minor adjustments.
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
LOT LOCATIONS (A52577)
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2008 INTERNATIONAL MA025 REEFER BOX TRUCK (A52577)
2008 INTERNATIONAL...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A51692)
2002 Western Star...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
