BX2200 Valve clearance check
   / BX2200 Valve clearance check #1
Barneyhunts
Dimock, Pa.
Kubota L4240 Kubota B7800, Kubota BX2200
My BX2200 has nearly 800 hrs. on it. Maintenance requirement is for a valve clearance check and I wonder if it is worth doing. Has anyone done it? What did you find? I use my tractor for mowing and snow blowing and have not noticed any drop in performance so I wonder if this check is necessary.
Thanks,
Barney
   / BX2200 Valve clearance check #2
Hi Barney. I did my first valve adjustment at 1170hrs. I only needed a minor adjustment to bring them into the mid-range of the specs.
Not a difficult task. Worth taking the time to check. Engine did run smoother afterwards.
Thank you for your quick response.
Barney
Have you ever seen a video on how to do this?
   / BX2200 Valve clearance check #5
I think there is one on youtube. If you have the workshop manual it walks through the process.
Thanks, I do have the manual. I'm not sure how to turn the engine over or how to determine TDC.
Barney
   / BX2200 Valve clearance check #7
Did my BX24 about 2 years ago. NOT hard. Used WSM. Minor adjustments.
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
2025 John Deere 3025E (A50120)
2025 John Deere...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Chicken Coop (A50121)
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
