Grading BX2200 - Turf tires with box blade
   / BX2200 - Turf tires with box blade #1
HelGen
How effective is the BX2200 with turf tires pulling a box blade? I've got mostly lawn/pasture, so turf tires would be best overall. But there are some areas that need some serious grading. Will a BX pull good without Ag tires?
   / BX2200 - Turf tires with box blade #2
The BX will not in my opinion give good performance with turf tires when pulling a 4 foot box blade. I usually ran out of traction even with the ag tires before running short on power when working my Kubota 7548 box. converesly, I found that the fairly wide ag tires on the BX did not mess my lawn unless it was soft and wet. Your conditions could be different however. An atomic bomb might not dent my lawn. J
   / BX2200 - Turf tires with box blade #3
If the surface your grading damp etc.. the turf tires will load up,but one cure for that would be put a set of rear tire chains on and use 4wd low range.
I've always like turf tires for fel work also mowing,but there are times I wish I had AG tires..plowing snow, going thru the woods,wet areas,slopes,pulling a loaded trailer etc...
Good set of rear tire chain w/turf tires are like night and day.
   / BX2200 - Turf tires with box blade #4
I use a 42" box blade with my BX2200 with turfs. I've had good success with graing a gravel drive and removing about 6inches of grass and soil for a concrete pad (8'x16'). I used 4wd low and didn't have a spinning problem but if I got the box too full or too deep, it would stop the tractor. The BX2200 has lots of ways to avoid/help with tire spin with the differential lock and the 4wd functions. I chose the turfs because I wanted the least aggressive tread on my yard when mowing.
   / BX2200 - Turf tires with box blade #5
I have a Woods 48" with turfs on my BX, and as long as i don't try and dig too deep, i don't have any problems. I imagine that chains would help, though. If i were doing a LOT of box blade work, I would consider purchasing a set of Ags...a complete set of tires and rims costs about $300....
   / BX2200 - Turf tires with box blade #6
Is that for all 4 tires and rims and was that thru Kubota or somewhere else? And are the ags less likely to get punchured by shredded sapplings, etc. I'm asking because I've had two slow leaks in my right front tire by what looked like shavings from a sapling stuck between the tread. Since I only will be using the rotary cutter every four to six weeks, a set of ags may not be a bad idea - for that price.
   / BX2200 - Turf tires with box blade #7
I was quoted either $325 or $350 (first thing to go is your memory, can't remember the second thing), for a set of bx2200 wheels/ags from my local dealer. He said shipping was $75.
mark
   / BX2200 - Turf tires with box blade #8
I ordered a set of ag tires and wheels for my Bx from my dealer. Price was $260.00 ,said he would not charge for freight if I waited for his normal stock shipment. Been 2 weeks,expect any day now.
   / BX2200 - Turf tires with box blade #9
Get them right from your dealer. As far as the slow leaks, Yea, I had them too, both of my Cubs and then my Bota. Had enough of that, so I had them filled with Agco's Soft fill, which has the consistency of Gel. No more leaks, ever, and still have as good a ride as I had with just air. I HIGHLY recommend it. You wont' have any more leaks and wone have to worry about peeling the tire of the bead when doing heavy FEL work.... If I remember right, both fronts were filled for about $120 total...
   / BX2200 - Turf tires with box blade #10
With the B8200 I have pulled 3 ton hay wagons with it and the tires will pull unless it's wet i have turf tires on it also
   / BX2200 - Turf tires with box blade #11
I can't help too much -- don't have a box blade (yet) but I've been pulling 4 and 5 inch elm and maple out of the ground with logging chain and a 2200 with turf tires. Seems to be working, I've only had the tires load up once to where I needed to use the diff. lock.
Tom
   / BX2200 - Turf tires with box blade #12
Just want to give my 2-cents worth... I have turf tires with box blade. I pulled up an old gravel drive way and dug up about 6 inches of top soil for an above ground pool using only unloaded tires. I had some spinning of wheels so I bought some rear tire chains. I just installed them last night and went out to play. At first I was a little disapointed because my wheels were still breaking loose and spinning, then I noticed I was only in two wheel drive. Put it in 4 wheel and what a difference that made. I was able to fully load up the box blade with dirt and drag it anywhere I wanted to go. Bottom line is if you have turf tires and are going to do some dirt work get some chains. I bought mine at <A target="_blank" HREF=http://www.tirechains.com/>http://www.tirechains.com/</A>.
Dave
   / BX2200 - Turf tires with box blade #13
About this changing tires depending on the task at hand - hope you're real strong or have lots of help. My buddy punctured a rear tire on his "green colored" tractor, which is in the mid 40hp range. So, we placed a very large jack under the tractor, and pulled the tire - oh boy was that large metal rim and ag tire heavy. That was the easy part - don't ever, ever let the dealer load (anti-freeze) a tire that you've taken in for patching. Darn near killed us getting it off the pick-up and back onto the tractor (yes, we were able to roll it most of the way). So, for smaller tractors without loaded tires - OK, but the chain option sure sound good to me.
   / BX2200 - Turf tires with box blade #14
You have a lot of varied response to this question for good reason. For the record I have turfs on my 2200.
It is my opinion there is nothing you can do with ags that you can't do with turfs, that is not to say the ags would not be more appropriate for some jobs. I have more than once wished for ag tires but have always managed to get the job done. I have used my 5' box blade(I had before BX) to remove sod from heavy clay soil with some rock and reshape two pretty long drives, my biggest traction problem was in the grass. Ag tires are not an option for me due to some soft areas of my yard but may take the advise about chains.
Blue Diamond 103709 (A53317)
Blue Diamond...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
1770 (A58375)
1770 (A58375)
