bx2200 tiller
   / bx2200 tiller #21
Steve,
You would think so, but in my situation, the max extension is roughly when shaft is parallel to the ground. The offset for the tiller is all or nothing, done by moving the A frame between two sets of mounts and the clevis brackets back and forth on the front bar of the tiller. The gear box is not directly in line with the PTO in either position, so there is always some offset in the u-joints. Through the whole range of motion, the shaft only moves about 2-1/2 to 3". In my case, the chattering at the top has to be the angle of the u-joints. The shaft can still overlap another 1" or so when it is making the noise. I've just gotten in the habit of dropping the tiller a few inches before engaging the PTO, then bringing it up to speed as I lower it. The only time it's an issue is when I try to bring the tiller up when finding a large rock. With the engine RPM's up, the lift arms usually come full up before I can stop it.
Kevin
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
PALLET BOX OF MISC (A58374)
PALLET BOX OF MISC...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
