BX2200 Tie rod end
   / BX2200 Tie rod end #1
JimC
Seguin, TX
Kubota BX2200
I have managed to tear two rubber boots on the tie rod ends. probable due to old barbed wire (acording to my dealer).
I had to replace the entire assembly as the rubber boot is not carried as a replacement.
Has anyone found a source of replacement boots for the tie rod ends
   / BX2200 Tie rod end #2
Jim:
I had the same thing happen on my BX22, although I was not in anything that I think could have caught the boot. I noticed the tear, but concluded that there must have been a small tear from new, and it just grew due to the wide angle swept by the joint. I replaced it myself, and the dealer swapped the part under warranty. Replacement was pretty easy, except for the narrow wrench you need to grab on the cylinder rod. I ended up grinding down an openend wrench to "thin" it to fit. Setting the toe-in was easy using the measurements in the owner's manual.
I did a little hunting for a replacement boot, but came up dry. I was thinking about trying to hunt down the manufacturer, but when the dealer said he would exchange it I gave up the hunt. But it might be good to find a supplier since they are held on with just a little wire clip.
I considered putting some of the cloth mesh that they have over the hydraulic hoses as a protective cover on the joint, using a couple of tie wraps to hold it in place. If I do find it gets torn I will most likely add the protection. Unfortunately they do hang out there with little protection.
Let's see if anyone else found a source.
Paul
   / BX2200 Tie rod end #3
Geez, Hadn't thought about the boot getting torn.... I might take some evasive action up front and cover them for protection like mentioned. They do hang out in the open for abuse....... Tom
24ft Corral Panels (A49251)
24ft Corral Panels...
2006 PETERBILT 357 (INOPERABLE) (A48992)
2006 PETERBILT 357...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A48992)
2019 ALLMAND BROS...
PARTIAL PUMP JACK SKID (A48992)
PARTIAL PUMP JACK...
7000LB Axle (pair) (A49251)
7000LB Axle (pair)...
12,000 LB Axle (pair) (A49251)
12,000 LB Axle...
