BX2200 Steering Leak?
   / BX2200 Steering Leak? #1
mvanditta
I have fluid leak problem with my BX2200. The leak is somewhere in the steering assembly (where the four hydraulic lines connect to the steering wheel). I have already had it in the shop to have this problem corrected, but it is back after putting only five hours on the machine. The dealer said it was a bad o-ring, but I believe that something else is wrong with the assembly. Has anyone else had a problem with leaks in the steering? I have only put twenty-two hours on the machine.
   / BX2200 Steering Leak? #2
I had a problem with the steering that was just fixed this week. There is a service bulletin on this. They replaced the hydraulic steering cylinder-bad manufacturer.
See the previous post "BX2200 Steering problem....solved" for more info. Also see the previous post "BX2200 Steering problem....solved...update"
Bob
LOT: (2) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (2) Kimball...
2017 Ford Explorer (A56859)
2017 Ford Explorer...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
kids dirt bike (A56859)
kids dirt bike...
116 Gallon Poly Fuel Tank W/12V Pump (New/Unused) (A59225)
116 Gallon Poly...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
