BX2200 steering giving me problems
   / BX2200 steering giving me problems #1
Blackplague
Kubota BX2200
Ive been wanting to buy a sub-compact tractor for years.. I finally saved up the $$$$ and bought a 2005 with a 60"mmm and a 211 loader. It has 213 hrs and the power steering is giving me crap. It will not turn to the right sometimes if u turn the wheel slowly.. Turn it fast and its fine. Turning left is always fine.. Also some times then i first start it these no steering at all for a few seconds ( like at all) I changed the tranny filter and it hasent done it sence.... I paid 6000 for the tractor and hope i didnt get the "shaft"..
I looked into this and it seems to be the front steering cly seal having damage and bypassing fluid? If this is so could i tear it down and put a new o-ring in the thing? Have these ever been recalled?
They sure need to....:mad:
   / BX2200 steering giving me problems #3
Welcome to TBN :D
What you are describing sounds like failed o-rings in the steering cylinder. Has been a frequent topic on BX's. You can rebuild the steering ram yourself, apparently the internal C-clips holding the thing together (on the ends) is the trickiest part.
Use the search function for "BX steering" and you will find plenty of info.
Russell in Texas
   / BX2200 steering giving me problems #5
Just in case...make sure your three point hitch lever isn't in the "up" position. It should be in the center. If it is stuck in up the steering and loader functions get wacky.
2012 KENWORTH T800(INOPERABLE) (A48992)
2012 KENWORTH...
2015 Ford Focus Sedan (A46684)
2015 Ford Focus...
JMR Root Grapple (A49251)
JMR Root Grapple...
1981 John Deere 4840 2WD Tractor (A49251)
1981 John Deere...
2012 DODGE Ram (A46684)
2012 DODGE Ram...
8ft QA Snow Pusher (A49251)
8ft QA Snow Pusher...
