BX2200 Starting Problem
   / BX2200 Starting Problem #1
pemad
Syracuse, New York
B7510 HST
I figured I would pass this on to others that may come across the same problem.
I went to start my BX the other day and did the normal procedure of putting the tractor in neutral and turning the key but nothing happened. The tractor did not turn over but just made the normal clicking noise. I assumed the battery needed a charge, but after hooking up the batter charger the battery had A reading of full. I then looked around the tractor and found the neutral switch (not sure what it is called) which needs to be depressed in order for the tractor to start. It was not, so I took off the rear tire to access the switch and found that the 2 bolts that hold the switch in place came lose. I readjusted the switch and I was off and running.
   / BX2200 Starting Problem #2
pemad,Thanks for the tip,I will keep that in mind.
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2020 FREIGHTLINER PT126SLP TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
