BX2200 Seat
   / BX2200 Seat #1
Anonymous Poster
Epic Contributor
I now have 22 hours on my BX2200 and the biggest item that disappoints me is the seat. The seat is very uncomfortable and it moves back and forth about a 1/4". Have any of you BX owners figured out a way to remove the play in the seat? I have been thinking about bolting my seat into position. This is a real annoying problem which could only be appreciated by someone spending time on the tractor.
   / BX2200 Seat #2
I now have 46 hours on mine, and don't have the seat movement. What I have noticed is that when you release the seat adjustment lever, the seat doesn't necessarily lock into position. That is, sometimes I have to jiggle the seat while pushing the lever towards the locking direction (after my sons are kind enough to readjust it for dad /w3tcompact/icons/smile.gif). When it clicks in, I have no discernable movement (outside of what the springs allow for lateral rock).
   / BX2200 Seat
Roy, Thanks for the reply. The latching lever on my seat must be under size. Because my seats moves at least 1/4".
Maybe I'll try to remove the lever and build it up by welding on it.
   / BX2200 Seat #4
Jon;
Before going to an extreme, have a dealer look at it. May be something simple (e.g. misalignment). One of the advantages of buying new, there is always the warranty.
   / BX2200 Seat #5
If the seat is moving about 1/4 inch make sure its latching both sides. make sure the whole seat is moving and not just one side. It may just take adjusting it where it bolts on the tractor.
   / BX2200 Seat #6
Wow!!!!
Responding to a 19 year old post. Might be a new record.:laughing:
Good advice, hopefully the original poster doesn't need it.
   / BX2200 Seat #7
I had a BX2200, I used it with the original seat for too many years. I finally looked into changing the seat, found out that if I had complained sooner, Kubota would have offered me a replacement seat. I ended up buying a seat from K&M Manufacturing, holy Mary mother of God what a difference!
   / BX2200 Seat #8
Original post made in 5/28/2000
And he joined in Sept 2005
:confused3: :laughing:
Guy was really ahead of his time...! Or is behind his time ???
   / BX2200 Seat #9
Maybe a time machine! I couldn't get my BX2200 up to 88 MPH, the Flux Capacitor may have had some issues too!
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
2004 Ford F-250 Ext. Cab Service Truck w/ Liftgate (A59230)
2004 Ford F-250...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
UNUSED 2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
UNUSED 2023 VOLVO...
(2) USED 3500 LB TRAILER AXLE W/ BRAKE (A60432)
(2) USED 3500 LB...
