BX2200 rotary cutter
   / BX2200 rotary cutter #1
Bill H
I am trying to buy a rotary cutter for my BX2200. Owners manual says max 42" and 300 lbs. The lightest I have found is a light duty Bush Hog Squealer at 356 lbs. All others are 400 lbs and above. Other than front end weight, I am concerned about damage to three point hitch and hydraulic system. Can anyone give me benefit of your experience with this?
   / BX2200 rotary cutter #2
You should be fine with the Squealer. I actually used a 5' cutter behind a BX2200. Not a good idea, but it worked.
The only problem you may have is lifting the tail wheel off the ground completely. Even this is no big deal. If you don't have a FEL, definetly add weights to the front end.
   / BX2200 rotary cutter #3
I use a 40" Gearmore heavy duty rotary cutter on my BX2200. It cuts almost anything, including 2" sapplings. A BX will lift about 1200 lb. at the 3ph, 600 lb if the center of gravity is 2' behind the 3ph. A rough cutter is long and thus has a cg that is farther than 2' behind the 3ph.
The manual doesn't give max. weights for implements used while the tractor is stationary: mixer, phd, generator, chipper, etc. For implements that are used while the tractor is in motion, the max weights listed are about half of what it will actually pick up. This is in case someone abuses the tractor (your nephew from the city visits and decides to take off racing the tractor across a furrowed field perpendicular to the furrows in order to make it bounce as much as possible). With a brush hog attached, the oscillation and G-forces from this abuse could break the 3ph. Listing the max. wt. so low allows Kubota to void warranty claims if overloading AND abuse both occur. You can easily lift more than the max. listed; just don't abuse the tractor.
A 5' light duty brush hog will do if all you're cutting is hay in a pasture. If you're cutting heavy, go with a 36" medium duty or the Gearmore 40" heavy duty. For medium usage, a 48" medium duty is a good choice.
Thanks. Ordered a Bush Hog 42". Kubota advised that lift capacity at lift points was 450lbs and 300 lbs 24" behind lift points. I expect it to handle it ok if enough hp.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
Fire Hose W/Holder (A50774)
Fire Hose W/Holder...
Honda ATV (A50121)
Honda ATV (A50121)
NPK H2XA Skidloader Breaker (A50774)
NPK H2XA...
KUBOTA M7-132 (A53084)
