Oil & Fuel BX2200 ran out of fuel
   / BX2200 ran out of fuel #11
We are gettting confused about what is occuring. I gather that when you say "Doesn't turn over"....it means that the engine is turning, but not "Firing". Do you have water in the fuel? When my BX starts...it belows a little BLACK smoke, not white.
   / BX2200 ran out of fuel #12
After reading all the above posts, I assume that he ran out of fuel completely, refilled the tank with diesel, and now it won't start. It turns but puffs white smoke and doesn't fire. Correct? You didn't put gasoline in the tank instead of diesel did you? (I did. That's why I've <font color="orange">Exalted</font> myself.)
With that assumption, how long have you tried to start it? You can easily pull the fuel line off the fuel injector pump, turn on the key to ON (not Start), and you should see fuel coming out. It will fill a pop bottle in only a few seconds. If fuel is getting that far then you are almost there! Crank for 5 seconds (remember to pull the choke knob) and if it doesn't start it isn't a fuel problem.
That's a joke, son, about the choke knob. You don't have one. Check your carbureator belts and muffler bearings while you're waiting for a call from that online dating service.
   / BX2200 ran out of fuel #13
Hello,
When I had water in the fuel of my BX 22 it had lots of white smoke. I think you may have gotten water in yours as well.
Try draning the tank and replacing your fuel filters and refueling with fresh fuel from a clean container.
Greg
Thanks to all of you that replied. I finally had time this past weekend to try some of your suggestions. It was water in the fuel line. I replaced the fuel filters and got some fresh diesel, now it cranks right up! I really appreciate all the advice and expertise of this forum. /forums/images/graemlins/smile.gif
1998 Chrysler Sebring JXi Convertible (A48082)
1998 Chrysler...
2011 Ford Edge SEL SUV (A46684)
2011 Ford Edge SEL...
2018 Atlas Copco HiLight V5 Plus Towable Light Tower (A46683)
2018 Atlas Copco...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A46683)
2017 JLG Skytrak...
2020 John Deere 5065E  4WD Tractor (A49251)
2020 John Deere...
2B Plow (A49251)
2B Plow (A49251)
