BX2200 pto clutch adjust
   / BX2200 pto clutch adjust #1
hdfxrs
Can the pto clutch on a BX2200 be adjusted. The belly mower deck seems to be slipping. The belt is new.
   / BX2200 pto clutch adjust #2
I don't think so. Was there a problem before you changed the belt or is that the reason you changed the belt? When was the last time you replaced the concave washers that tighten the blades to the spindle?
   / BX2200 pto clutch adjust #3
The PTO clutch is wet and not adjustable except for lockup pressure. I suggest you get a workshop manual if you want to set the lockup pressure, it is adjustable.
   / BX2200 pto clutch adjust #4
I have a feeling your blades are loose. Check your blades and make sure they are snug before venturing into the transmission case.
   / BX2200 pto clutch adjust #5
I had this problem with mine one time.
Has not been cutting well for some time. Washers are new and blades are tight. I can move the blade by hand even when the mid pto is engaged (motor is off of course). Not sure this should be possible. Rear pto cannot be turned when engaged (turns easily when disengaged). This made me think the mid pto clutch might be slipping.
I have a manual, but don’t see anything about the lockup pressure.
   / BX2200 pto clutch adjust #8
Hmmmm. I'll be going out to my shop in a couple of hours. I'll engage the pto and see if I can spin the blades.
   / BX2200 pto clutch adjust #10
On pages 2M14-16 in the workshop manual and lists the requited lockup pressure and adjustments. You need to download a copy of the WSM from Kubotabooks. The control valve will external, on the side of the transmission case (as is all Kubota's).
I didn't really want to look but I did because I have the time.
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2023 JOHN DEERE 7R210 LOT NUMBER 95 (A53084)
2023 JOHN DEERE...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
