BX2200 - odds of 1 in ??
   / BX2200 - odds of 1 in ?? #1
BXMMCC
South of the C & D, on the banks of the Bohemia ri
Kubota BX2200
Using the rake the other day, just happened to hear a metallic clink when lifting the 3pth. Found the right upper lift arm's hairpin clip on the ground. What happened - the lift arm pin evidently rotated into a position that had the clip inverted and at such an angle that the straight end of the clip contacted the rear cross support and was pushed out!
   / BX2200 - odds of 1 in ?? #2
I have lost many clips and pins because of these type of problems in the past. I just keep spares for just this reason. I have even though about welding a loop on the end of pins and hooking a cable to them like on the ROPS. Loosing pins and clips is just one of those things you learn to not get upset about. I even loose them before I even get to use them.... I know that they are in the garage somewhere, just not where. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / BX2200 - odds of 1 in ?? #3
Can't remember exactly where I got 'em, but I bought a bunch of pins that close & hook on the end, sorta' like a diaper pin, 'cept the end isn't sharp or capped over. They're the same diameter as my regular pins. You might want to do a search. I'll check some catalogs & see if I can figure out where they came from. They sure are handy.
2019 KENWORTH T680 DAY CAB (A50046)
2019 KENWORTH T680...
New Holland 56 Rake (A49251)
New Holland 56...
2014 Ford F-250 Pickup Truck, VIN # 1FT7W2B66EEA79923 (A48836)
2014 Ford F-250...
10-16.5 SKS1 Tires (set of 4) (A49251)
10-16.5 SKS1 Tires...
Ford Pick Up Bed (A49251)
Ford Pick Up Bed...
3pt 9ft Back Blade (A49251)
3pt 9ft Back Blade...
