BX2200 - odds of 1 in ??
   / BX2200 - odds of 1 in ?? #1
BXMMCC
South of the C & D, on the banks of the Bohemia ri
Kubota BX2200
Using the rake the other day, just happened to hear a metallic clink when lifting the 3pth. Found the right upper lift arm's hairpin clip on the ground. What happened - the lift arm pin evidently rotated into a position that had the clip inverted and at such an angle that the straight end of the clip contacted the rear cross support and was pushed out!
   / BX2200 - odds of 1 in ?? #2
I have lost many clips and pins because of these type of problems in the past. I just keep spares for just this reason. I have even though about welding a loop on the end of pins and hooking a cable to them like on the ROPS. Loosing pins and clips is just one of those things you learn to not get upset about. I even loose them before I even get to use them.... I know that they are in the garage somewhere, just not where. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / BX2200 - odds of 1 in ?? #3
Can't remember exactly where I got 'em, but I bought a bunch of pins that close & hook on the end, sorta' like a diaper pin, 'cept the end isn't sharp or capped over. They're the same diameter as my regular pins. You might want to do a search. I'll check some catalogs & see if I can figure out where they came from. They sure are handy.
Stump Grapple (A49251)
Wolverine Hydraulic Tiller Skid Steer Mount (A47371)
Wolverine...
2005 Great Dane Trailer, VIN # 1GRAA96265S700587 (A48836)
2005 Great Dane...
JMR Stump Bucket (A49251)
JMR Stump Bucket...
TOFT 04ER Excavator Ripper (A49251)
TOFT 04ER...
45017 (A48082)
45017 (A48082)
