BX2200 not running smooth
   / BX2200 not running smooth #1
Rickyj66
Hi, I have just returned home after a couple months on a job. My nephew had helped keep the grass down with my tractor. Now that I have started it it is running very uneven. I bled the injectors and find that number 1 and 3 are pulling the load as the tractor will cut out when I bleed either one of these but the number 2 will only register a slight difference.
Any ideas?
Ricky
   / BX2200 not running smooth #2
I'd start with the simple stuff first...air filter than the gas filter...Mowing is very dirty!!:)
   / BX2200 not running smooth #3
Always in the back of my mind when others have access is: Could regular gas have been put in rather than diesel?
New/Unused AGT Industrial SDA-140T Track Loader (A57453)
New/Unused AGT...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2022 K-Z Sportsmen LE Trailer, VIN # 4EZTU2621N5051599 (A57453)
2022 K-Z Sportsmen...
Miscellaneous Chairs (A56860)
Miscellaneous...
Hatz Diesel 6 Inch Water Pump (A57453)
Hatz Diesel 6 Inch...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
