BX2200 My First Disapointment!
   / BX2200 My First Disapointment! #11
Fishman,
Your recall is pretty good. The LA211 (BX2200) max lift height 71.3 inches, LA302(B7500) Max lift height (to bucket pivot pin), 69.5 inches.
Clearance in dump LA211 - 51.2 inches, LA302-52 inches.
My wheelbarrow max height before dump is 14.5 inches to bottom of the bucket, whats yours? /w3tcompact/icons/smile.gif
Al
   / BX2200 My First Disapointment! #12
if i sent this to you allready im just learning how to use the site. take the loader and dig a hole to back the truck in. and your other problem i think the 905 is bx1800 and 1005 is bx2200
   / BX2200 My First Disapointment! #13
Just another example of how the "too little" BX can do things we keep getting told it cannot. Oh well, get a bigger tractor and when it squashes your yard, cannot fit through your gate, or mow you hillside or turn around under your deck or fit in your garage or do all the things the BX can do so well--better than it's bigger brothers you can buy another. Yes--the BX has more lift and reach than the 7500 loader--I am looking at here in the brochure right now--oh well--next. I am hoping to be voted BX High Cult Priest, I will now go and kneel before the Mighty BX and offer it fresh oil and a wax and perhaps a burning of L Series brochures to lesson her anger. J
   / BX2200 My First Disapointment! #14
Thats a great truck! and it looks like its in great condition! What size engine is in it? and what did you pay for that gem? I would love to find one in that shape, just to have when needed. Oh, buy a bigger tractor to fill it!
   / BX2200 My First Disapointment! #15
build a small ramp, should not take long, u can't need that much more height to dump over the side..
It is an in line 6 cyl, weren't they 239 cu inch. I can't remmeber. I have has it for three years. It's great. Every fall I take out the battery. In the spring, I put it back in pull out the choke pump the crap out of the gas petal for about 5 sec and start turning it over while pumping and 2 sec later its running like a top for the rest of the season.
It has a two speed rear end. To bad it's not three speed. I am always looking for 5th gear on the hwy when it tops out at 50 mph. At which point, because it has no radio (truck is too loud anyway) and there is no 5th gear, I start singing (screaming) I CAN'T DRIVE 55.
It has 32,000 miles on it and it is an ex-grain truck.
I paid $1,500 for it and another $400 for an old set (6) of brand new tires. I have a used windshield sitting in the shop waiting to replace the cracked one.
We call it Hank. My wife's deceased Uncle Hank had one just like it.
Winnipeg, Manitoba
2001 BX2200 (20 hrs) All Kubota FEL,Tiller, box blade, blower w/elec shute, 60 mid mt deck, Ag tires.
Grey market B7000 w/Tiller (120 hrs)
1984 JD 316 after 687 hrs.
   / BX2200 My First Disapointment! #17
TresCrows,
You shore do like your BX./w3tcompact/icons/smile.gif I also got the numbers for the loaders from the sales brochure. They may not compare one to one. Neither brochure identifies very well how the measurements are taken. It's a little curious why the LA 302 has 52" of clearance when the bucket is in dump while the LA211, with about 2" higher max lift has a clearance in dump of 51.8". Longer bucket?? The max. lift height for the LA302 was to bucket pivot pins, the location for the LA 211 wasn't defined. I think fishman got it right, nearly identical. As far as "BX High Cult Priest" you sure got my vote. I don't think the job pays that well, but I could be wrong. My wife still reminds me that her B7500 does not have the cup holder like the BX/w3tcompact/icons/smile.gif
Al
   / BX2200 My First Disapointment! #18
I saw my first 7500 when I drove the BX with FEL yesterday. The only thing I liked better about it was the tach. Even money, I wouldn't trade. Course it may fit others needs better than mine.
Rogue
   / BX2200 My First Disapointment! #19
Actually again despite the naysayers who insist the BX is weighed differently from other Kubota tractors and now it is that the FEL is measured differently!? Nope, the brochure and my operator manual show the measurements are taken in the same way. The BX has more height than the 302--sorry--but the BX pulls out on top in this case! The measurements are taken from the brochure on the 3rd page of the B1700/B2100/B2400 and 7400/7500/2710/2910 brochures and several others I have that shows a diagram of the tractor with loader attached and gives designations for the various measurements. The BX brochure does give the same measurements but does not have a diagram demonstrating them but much to the dismay of the naysayers it is in the operators manual on page 7 for the FEL. Yeppers, the BX has, when measure in exactly the SAME way--the SAME way---71.3 inches of max lift height vs 69.5 for the LA302 on a 7500. Soooo by doing some reserch and because I have a pile of old and new brochures and the FEL manual for the LA211 I can assure you that the measurements are taken in the same way with the loader mounted to the tractor and used in exactly the way it was intended to be used. Also, I have been told that the weight of the tractors including the BX are taken the same way, stripped and field ready.
It is not so much that I like the BX but instead just want to see the correct figures and capabilities of the tractors stated and not urban legend. Fact is the BX has a heavier mower deck than the B series (right here in brochure 9 guage vs 9.5), wider/lower more stabe stance, manuvers better in close quarters, can work the implements Kubota listed for it with ease etc equal to it's larger siblings--why would only the BX be different as if Kubota was trying to trick people? What good would that serve them? /w3tcompact/icons/wink.gif .J
BX High Cult Priest you have my voe.
Winnipeg, Manitoba
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2007 Ammbusher DL66 Hydraulic 66in Brush Cutter Skid Steer Attachment (A55973)
2007 Ammbusher...
2016 GREAT DANE 53’ REEFER TRAILER (A58018)
2016 GREAT DANE...
DEUTZ MARATHON...
2012 Jeep Grand Cherokee SUV (A56859)
2012 Jeep Grand...
2014 PETERBILT 579 MID-ROOF SLEEPER (A58214)
2014 PETERBILT 579...
