toddler
- Joined
- Jan 26, 2001
- Messages
- 407
- Location
- North Carolina, USA
- Tractor
- Previously: Kubota B2710. Now Deere 3520
That makes us neighbors Pat,
Did you buy from Gary in Essex, Walt down by Montpelior, or elsewhere? If you bought from Gary, I'd ask him if he'd loan you a 4' or 5' woods, if you'd consider buying from him. I personally liked the woods he sells better than the king kutter at CT, although I can't recall the price difference.
I've got a little 48" woods you're welcome to try. I honestly think it's the max for the BX. Mowers will probably take a little less HP if their blades are sharp, because they cut, rotary "cutters" tend to smash and tear. I think that's why kubota recommends a smaller cutter than mower. 48" vs 72" as on my tractor might be overly cautious (clearly is since I seem to be the only person without a 60"), but 48" vs 60" on yours seems about right to me.
Given what you plan on cutting, why don't you stop by my place and see just how badly a rotary cutter cuts compared to a mid mount mower. It's not awful, but it always misses a few stalks which then pop back up. It's only advantage is that the blades are on pivot pins at the end of a spinning bar, so they pivot back if you hit something too solid, and then just keep smashing at it. That's instead of stalling or slipping a clutch which would happen with a solid mower blade.
You're welcome to try my cutter on your BX if you can bring it over, or on my toy. Given what you're describing, I'd get a 60" mower and just sharpen the blades once or twice a season. Midmount or 3pt would work, but the mid mount would probably let you do a lot of the cutting around your house. If you can drive the naked tractor close to the house, you can cut with it with a Mid Mount, which saves time with a walk behind.
I just cut down the unused part of my garden with my MMM on Sunday because I was too lazy to put on the cutter. Worked fine. A BX with a MMM, front thrower, and FEL, is an awsome set up.
Todd
One last thought, you can go faster with the MMM or finish mower on light stuff, than you can with a cutter. Gotta go real slow with the cutter or it doesn't do the job.
Todd
