BX2200 Implements
   / BX2200 Implements #1
GONO2
South Central Virginia - GONO2 = Go # 2
JD 790
Hello All - I am new to this forum so please forgive me if this has been asked before.
I am getting ready to purchase a new BX2200 with a 60" deck and FEL. It will be used for work on my 27 acres for mowing and general manteniance and some gardening. The horses cut most of the grass so mowing is down to 5 acres or less. I have been reading your posts for hours and am wondering what types of implements are being used with this tractor. I realize that the ground clearance is not great. Please add to the list below if you use something else. I am particularly interested to know if one of you are pulling a small 2 bottom plow with the BX2200.
Thanks so much for the input and help!!!
FEL
Mid-Mount mower
Snow Blower
Front Blade
Rear Blade
Box Blade
Post Hole Digger
Rotary Tiller
   / BX2200 Implements #2
Well, I hit on 5 of the implements you listed. Add a Pulverizer to the list. I think i can say that those of us the have a BX pretty much love them. They have their limitations, but so does every other tractor on the market.
the two bottom plow may be one of those limitations. It MAY do it if you have the right soil (soft, loamy) and the right tires, but you are starting to push the limitations of a small compact tractor. Accordint to the manual for the BX, it'll pull a single bottom. I just got a tiller instead. It's a Howard Rotavator HR3 50" and the BX handles it just fine in hard clay.
   / BX2200 Implements #3
PTO spreader such as the Herd M-96, PTO sprayer, flexible Harrow, 40 to 48 inch rotary cutter, look at the recent thread about KK XB implements. J
   / BX2200 Implements #4
Look at this. J
   / BX2200 Implements #6
I have never used one but I have seen small discs like this one used. It's usefullness depends on your expectations. For keeping a garden plot, beds etc I think you need a tiller but for breaking the crust on ground, pasture renovation (scratching the surface up) etc these are fine. In softer soils they turn up pretty good and you can add ballast to them for better penetration. The BX will run out of traction and spin so you would use this implement with the FEL attached for ballast weight and filled tires might be nice also. I want one, I know that and I am going to use it on the 2410 as well.
J
   / BX2200 Implements #7
Sorry, here is a closeup pic. J
   / BX2200 Implements #8
Heres my list
LandPride 1542 Tiller
LandPride RB1560 Rear Blade
WorkSaver Sub-Soiler (had to cut a few inches off)
WorkSaver Middle-Buster
SpeeCo (TSC) Post Hole Digger (a bit big, had to cut the auger down)
KingKutter XB rear dirt-scoop
and the standard 60" MMM
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2022 Horizon Trailer (A55973)
2022 Horizon...
PALLET OF MOWER BLADES & MISC PARTS (A58374)
PALLET OF MOWER...
SKID STEER ATTACHMENT GRUBBING BUCKET (A58214)
SKID STEER...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
TOOLBOX & AIR TANK (A58374)
TOOLBOX & AIR TANK...
