Oil & Fuel BX2200 HYDRO FILTER BLOWING. HELP!!
   / BX2200 HYDRO FILTER BLOWING. HELP!! #11
Broke down and took the machine to the dealer in Oxnard, CA. I tore down the entire machine and checked the relief valves for blockage, found nothing. Not knowing enough about these machines I did not want to tear down the HST pump. The dealer found melted plastic pieces in the unit and said that it grooved the plates inside the HST pump. I am not familiar with the internals so I not sure what they are referring to.
The machine is back together and seems to be working first day back. After $2700.00 repair. The new HST pump was $1500.00. This seems like a weak point on the machine considering it was damaged so easily and costs so much to replace.
Hope this helps someone out there. It seems as the dealer just replace the entire HST unit. Rather than re-build we'll see how long it lasts.
Thank-you very much for reporting back the outcome. Too often, threads just drop.
I am sorry it cost so much, but I am glad it is running fine again. I would not have predicted that cause for those symptoms, but sometimes it works out that way. Thanks again for letting us all know.
   / BX2200 HYDRO FILTER BLOWING. HELP!! #12
I presume the plates the dealer is referring are the port plates which is where the cylinder blocks rides on. Some of these have a brass finish and some are metal. Any hard object in them will destroy them. If there was plastic in them I have no idea where that would have came from unless Kubota has filled the pistons with plastic or epoxy for weight reduction. I haven't seen that done since the 70's though.
Roy
Bobcat S740 (A57148)
2025 GPS Trailer (A56858)
2025 GPS Trailer...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
