Loader BX2200 Hydraulics Problem with LA-211 Loader
   / BX2200 Hydraulics Problem with LA-211 Loader
The power and power beyond come from the same block... IMG_20190109_163123.jpgIMG_20190109_163123.jpg
The lines are plumbed correctly. The loader works fine on another tractor. We tested the pressure on the tractor and it was 1800psi. Volume was only about 2gpm. 3 point and steering work fine. Plenty of hydro in tank. I am thinking the valve is the culprit. Also, why would the pressure be good but not the rate?
   / BX2200 Hydraulics Problem with LA-211 Loader #14
Sounds like a bad/damaged spool for low flow.
   / BX2200 Hydraulics Problem with LA-211 Loader #15
That would depend on where the engine was for this test. If it's like our bx2660, there is a priority steering valve which takes all of the hydraulic flow until you get the engine up over 1300 RPMs. As such, until you get the engine up to there you do not get any flow to the hydraulic valves for the three point hitch and the loader or front attachments.
Aaron Z
   / BX2200 Hydraulics Problem with LA-211 Loader #16
Just a guess on my part...
The pump might be rated using a standardize bench test versus on tractor with hoses and such (more restriction).
   / BX2200 Hydraulics Problem with LA-211 Loader #17
I'm attaching a hydraulic flow chart for a BX23. It may or may not be useful as the BX23 includes an additional loop for the BH. Otherwise the basic flow may be the same. I'll swag your plumbing to the FEL valve is incorrect or the FEL's valve is bad.
   / BX2200 Hydraulics Problem with LA-211 Loader #18
   / BX2200 Hydraulics Problem with LA-211 Loader #19
So, pink is high pressure out to the loader valve and orange is the return from the loader valve (per Volfandt's 2nd diagram)?
Aaron Z
Per this link to the BX2200 hydraulic block in the WSM HERE , in OP's pictures, orange should be high pressure to SCV, pink should be PB from SCV and yellow should be return from SCV
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
VINTAGE JOHNSON OUTBOARD MOTOR (A58374)
VINTAGE JOHNSON...
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
