Bx2200 Hydraulic Leak
   / Bx2200 Hydraulic Leak #1
dwb
North Central Massachusetts
Kubota BX2200
Just a heads up for folks with a Bx2200. Mine has about 350 Hrs and has developed a hydraulic leak in the steel supply line to the loader valve where it crosses over the frame. There is a small clamp that holds the lines to the frame. One of the 1/4-20 screws was rubbing on the pressure line, leak resulting. Nothing a little rubber boot wouldn't cure.
Update: Dealer ordered the wrong part - doh! The correct part
is called Tube 2 Pump 75538-68470. The wrong part is 75538-35470. Loader serial# 12325.
   / Bx2200 Hydraulic Leak #3
I just replaced mine for almost the same reason, I had caught the flex hose on the loader while backing away and the hard line bent at the clamp and ultimately started to leak.good as new now, just need to be more careful.
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2018 AMERICAN HAULER (A52576)
2018 AMERICAN...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
