Bx2200 Hydraulic Leak
   / Bx2200 Hydraulic Leak #1
dwb
North Central Massachusetts
Kubota BX2200
Just a heads up for folks with a Bx2200. Mine has about 350 Hrs and has developed a hydraulic leak in the steel supply line to the loader valve where it crosses over the frame. There is a small clamp that holds the lines to the frame. One of the 1/4-20 screws was rubbing on the pressure line, leak resulting. Nothing a little rubber boot wouldn't cure.
Update: Dealer ordered the wrong part - doh! The correct part
is called Tube 2 Pump 75538-68470. The wrong part is 75538-35470. Loader serial# 12325.
   / Bx2200 Hydraulic Leak #3
I just replaced mine for almost the same reason, I had caught the flex hose on the loader while backing away and the hard line bent at the clamp and ultimately started to leak.good as new now, just need to be more careful.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
