BX2200 hydraulic issues
   / BX2200 hydraulic issues #1
149owner
MA
Cub Cadet 149, Kubota BX2200, LX3310, JD LX277
I have a 2001 BX2200 with less then 700 hrs on it. I've changed the hydro oil and filter several times, with Kubota oil & filters, never finding metal filings in the used oil. The oil is at the full mark on the stick. The problem I'm having is with the loader bucket. Sometimes when I set the bucket at a slight downward direction to back drag and then set the loader to the float position the bucket will loose its position and roll back up so it's flat on the ground. When you pull down on the control lever to lift the loader up the bucket rolls down on it's own until you move the lever to the left to raise it back up. It's acting like the bucket is in a float mode. At other times when I try to set the bucket so the front edge is flat on the ground to cut down high spots as I move forward and I "tap" the lever to curl the bucket up just a little bit, the bucket will roll all the way up instead of moving just a little bit at a time. Is this an issue with a valve sticking inside the control box that the lever is part of? Thanks for your replies.
   / BX2200 hydraulic issues #3
Double check the 3 hose connections on the side and make sure they are seated properly. Is the bucket curl the only hydraulic issue you are having? If so, you can concentrate your troubleshooting to that hydraulic line.
   / BX2200 hydraulic issues #4
Sounds like the spools are shot in the loader control valve.
Time for service.
Thanks for the replies! If the piston seal is bad wouldn't I have a problem with the bucket most of the time, not only when I'm trying to make small adjustments in its position? I'll check the hose connections to see if there are any leaks. They have never been disconnected since the tractor was new.
2016 Ford Explorer...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
John Deere 6420 (A50120)
John Deere 6420...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
